[ Tmux ] Terminal multiplexer
About: https://github.com/tmux/tmux
Category:
Applicable TOS4:
Applicable TOS5: 5.1.29 or later versions
App download: https://tmnascommunity.eu/download/tmux
TOS4: http(s)://yournasip:port/modules/pgAdminOKM/www
TOS5: click on Support & Help from app description inside the App Center
About:
tmux is a terminal multiplexer: it enables a number of terminals to be created, accessed, and controlled from a single screen. tmux may be detached from a screen and continue running in the background, then later reattached.
