OneDrive Sync does not accept USB drive as source
sglebs
Post by sglebs »
When you configure a OneDrive Sync task, you cannot define that your "Local Directory" is a folder in an attached USB drive. It only takes folders in the internal disks. Can this please be fixed? I use the internal drives for TimeMachine and the USB drive for a shared 1TB drive which I want to backup to OndeDrive. I see no reason why not to permit anything under "usbshare1"(in my case) to be a "Local Directory" in a sync task task. Thanks for listening.
Re: OneDrive Sync does not accept USB drive as source
Hi, we have sent your request back to the relevant project team.
Return to “CloudSync”
