Precautions when using TerraMaster USB storage devices
FAQs and instructions only for USB series raid storage
Applicable models:
D2-310
D5-300C
D5-300
If you are a new user of TerraMaster USB storage devices, please pay attention to following subjects:
1. When you press and hold the reset button for 5 seconds, the data on your hard drives will be deleted. Therefore, please proceed with caution;
2. Do not remove your hard drive while it is being accessed;
3. This device does not support hot swap. Therefore, before you replace a hard drive, please safely eject the device from your computer every time;
4. Before you turn off your device or disconnect it from your computer, be sure to remove it and eject it safely. Otherwise, there is a risk of data loss;
5. When you turn off your computer, hibernate your computer, eject the USB device, or remove the USB connection, the device will automatically enter hibernation; When you access the hard disk or connect the USB device again, the device will cancel hibernation.
Return to “USB Series”
