Virtualbox dont work TOS 5.1.24
gretor
Post by gretor »
in Version 5.1.24 when I start VIrtualbox I get:
What can I do ?
greets
gretor
TNAS F2-221 - TOS 5
4 GB Ram
2x 4 TB WD Red - Raid 1
Re: Virtualbox dont work TOS 5.1.24
Please try to re-enable the VIrtualbox.
If it doesn't work, try to log in to the SSH terminal and restart the php service.
/etc/init.d/php-fpm restart
gretor
Post by gretor »
Thanks,
That works.
Greets.
TNAS F2-221 - TOS 5
4 GB Ram
hal3390
Germany
Initial userid and password needed
Post by hal3390 »
I run a F5-221 with TOS 5.0.176-00227
I installed Virtual Box
I couldn't found initial userid and password anywhere in documentation or forum
Please help
Regards Roger
Over 40 years IBM Mainframe as z/OS and DB2 system specialist on the road, PC's, Internet and a TERRAMASTER F5-221 are my hobby :D
Currently using TOS 5.1.67-00214
{L_BUTTON_AT}hal3390
default username:admin
default passwrod:admin
godly
Post by godly »
TMSupport wrote: ↑22 Mar 2023, 14:22 Please try to re-enable the VIrtualbox.
Hi, i tried this:
https://imgur.com/a/Mb32B0L
But still get the same error:
https://imgur.com/a/7cnfOo9
{L_BUTTON_AT}godly
The libpcre2-8.so.0.10.1 file may be missing, please put it under /usr/lib/ https://download2.terra-master.com/libpcre2-8.so.0.10.1
godly
Post by godly »
{L_BUTTON_AT}godly
TMzethar wrote: ↑06 Apr 2023, 19:07 The libpcre2-8.so.0.10.1 file may be missing, please put it under /usr/lib/ https://download2.terra-master.com/libpcre2-8.so.0.10.1
How do I navigate to this folder and copy the file across? Is there a way to navigate using the GUI? Or can you tell me how to do this using SSH?
godly
Post by godly »
{L_BUTTON_AT}godly
godly wrote: ↑06 Apr 2023, 19:37
I looked for the file using SSH and it looks like the file is present: https://imgur.com/a/dHuksMy
[at=godly post_id=25936 time=1680781614 user_id=6806][/at]
Please check if the two soft links in question exist.
If you can't find them, please create them with the command:
cd /usr/lib/
ln -s libpcre2-8.so.0.10.1 libpcre2-8.so.0
Return to “Virtual Machines”
