I have ARM TNAS running 4.2.41
The installed AFPD/Netatalk is vulnerable as it is only at version 3.1.12
https://www.bleepingcomputer.com/news/s ... ical-bugs/
When will this be updated for ARM?
This vulnerability has been known about and a fix released by Netatalk for OVER A YEAR NOW.
Very poor! You should be ashamed of your lack of response to this vulnerability TerraMaster.
AFP Version Vunerable
- crisisacting
- Silver Member
Re: AFP Version Vunerable
AFP was deprecated by Apple on newer MacOS versions (10.9 and newer), so this should just be removed altogether, since it's vulnerable & even Apple wants users to move away from it.
Unless there is a reliable solution to using SMB drives for Time Machine Backup that doesn't require me to re-partition my RAID array so that I can prevent the backups filling up my whole array then I'll be using AFP.
Besides the x86 TOS 5 version does have the 3.1.13 AFP version which has the security vulnerabilities resolved.
Why can't us ARM users get a fix as well.
afp is an abandoned file service, I have disabled it.
