Suddenly decrypting Encrypted Shared Directory is failing on my F2-210
merge
Post by merge »
hi, I just upgraded to the latest Version on my Terramaster F2-210, to 4.2.41. I use RAID 1, simply 1 Volume, where I only use one Directory: an Encrypted Shared Directory, encrypted with a password. Now decrypting fails! (the yellow message is popping up).
The password is correct, because even creating a NEW encrypted dir, fais to decrypt with a new known-good password!!
Disks are both good. What can I try to do? Is this known? thank you!
Re: Suddenly decrypting Encrypted Shared Directory is failing on my F2-210
Can it be mounted normally with the exported key file?
