My computer won’t recognize the hard drive, and no drive letter appears?
FAQs and instructions only for Thunderbolt series raid storage
Troubleshooting:
Applicable models:
TerraMaster D2 Thunderbolt 3/TD2 Thunderbolt 3 (D2-330)
TerraMaster D4 Thunderbolt 3 (D4-330)
TerraMaster D5 Thunderbolt 3 (D5-330)
TerraMaster D8 Thunderbolt 3 (D8-330)
If you have installed the recommended hard drives into your TerraMaster Thunderbolt 3 device, but your computer won’t recognize the hard drives, please try following solutions:
1. If the hard drive indicator is off, please confirm whether the hard drive is installed properly. Remove and insert the hard disk to try again;
2. If the hard drive indicator is green, go to Windows Disk Management to initialize the hard drives, or use the MAC disk utility to erase the external device;
Note:
The default factory mode for your device is SINGLE mode. In SINGLE mode, every hard drive displays a different drive and works independently; If you install a hard drive with data and want to use SINGLE mode, you can simply start using your device without changing any settings.
