Backup to Drive #2
Discuss understanding the various backup tools available and choosing the one that's right for you
Jadius
Backup to Drive #2
Post by Jadius »
Hey
is there a way, to make the NAS automatically copy Drive #1 to Drive #2 at a specific time every day? So that Drive #2 is a 100 % copy of Drive #1.
My NAS is the F2-210, Version 4.1.21
Thank you
Re: Backup to Drive #2
Hi, you can set two drives works independently and create one volume one each of them.
Create one shared folder on each of volume.
Then install the Duple Backup from application center.
Set a scheduled backup task to back from one shared folder to the other.
Hopefully this is what you need.
Hi Jadius,
I am sorry to tell you that there is no Duple Backup for F2-210 for the time being. You can use Rsync backup to backup your data from volume 1 to volume 2. You should create shared folders on each of volume.
Please set your TNAS as Rsync server, you can configure it at TOS Control panel – Network services –File services –Rsync server as the following picture shows. Please be noted that the folders you created on volume 2 which will be set as destination folder should be added to “Authorized directory”.
Then you can go to Backup on TOS desktop, and check “Rsync Backup” to set up your task.
valery121
Post by valery121 »
Then install https://aduk.de/ and the Duple Backup from application center.
sianderson
Post by sianderson »
this is just a silly comment, but if this is your intention why wouldnt you set up the drives in raid so it auto backs up onto two drives? and also backup to a USB drive?
F2-424 TOS 7.0.1298
F2-423 TOS 7.0.1298
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Jadius wrote: ↑16 May 2020, 14:22 Hey
Thank you
Or You can just set two drives as RAID 1 configuration, then these two drives will keep all the same wothout doing any backup.
Return to “How to back up? Which one is right for me?”
