Does TOS5 work on the F5-221?
SquarePeg
Wales
Post by SquarePeg »
I've had problems when moving to TOS5 in the past so went back to TOS4. Is this working now or should I stay on TOS4?
TMLyy
Re: Does TOS5 work on the F5-221?
Post by TMLyy »
{L_BUTTON_AT}SquarePeg
Follow this guide to reinstall TOS5. viewtopic.php?f=76&t=423
SquarePeg
Wales
Post by SquarePeg »
Thank you for the link on how to reinstall but I want to know if it works properly
powerQ
Singapore
Post by powerQ »
The TOS 5.0 is fine, but not the TOS 5.1, TOS 5.1 is still buggy now.
SquarePeg
Wales
Post by SquarePeg »
powerQ wrote: 16 Mar 2023, 09:43 The TOS 5.0 is fine, but not the TOS 5.1, TOS 5.1 is still buggy now.
Thanks. Do you know if Emby works ok on this? I had problems with it before - the NAS would randomly stop/freeze/shutdown and Emby would have to be removed and reinstalled as it wouldn't launch. Not an Emby problem by the way because the same happened with Plex
SquarePeg
Wales
Post by SquarePeg »
SquarePeg wrote: 16 Mar 2023, 20:23
Actually nevermind, I did a factory reset and I can't even get to the option to choose an OS now
Please describe the issue you encountered in detail and provide a screenshot of the error.
Return to “System Update”
