I have recently been attempting to repair corruption on my 3 ext4 partitions.
One of the things I have noticed is that these were created without a journal.
Is this how TOS creates ext4 partitions?
I was genuinely surprised to find none of the partitions had journals.
EXT4 partitions with no journals
TMLyy
Re: EXT4 partitions with no journals
{L_BUTTON_AT}matt_30
What is your system version? Can you describe the problem more clearly? It is better to attach a screenshot of the log.
Apologies I will rephrase my question:
My current system version is 5.1 however, I have had my F4-422 since the 4.x days.
My device has 3 X ext4 partitions.
I have noticed none of them have journaling enabled:
Is journaling meant to be turned off by default for a reason?
[matt@TNAS ~]# dumpe2fs /dev/mapper/vg0-lv0 | grep features
dumpe2fs 1.46.5 (30-Dec-2021)
Filesystem features: ext_attr resize_inode dir_index filetype extent 64bit flex_bg ea_inode sparse_super large_file huge_file uninit_bg dir_nlink extra_isize
[matt@TNAS ~]# dumpe2fs /dev/mapper/vg0-lv1 | grep features
[matt@TNAS ~]# dumpe2fs /dev/mapper/vg0-lv2 | grep features
Hi @TMLyy
Was this enough Information, or do you need more?
We will check with our tech team and come back to you soon. Thank you
Good day,
Do you an update on this?
Yes, currently journal is disabled, will enable it in the coming releases.
Hi @TMroy,
Thank you for confirming.
Will this modify existing partitions or, will it only apply to new partitions.
I'm quite keen to get it enabled. I just wish to do it in a supported way.
Kind Regards,
Matt.
Kind Regards,
Matt.
Just update to 5.1.29, journal can be enabled for the existing file systems.
