RSYNC fails again
mowy
RSYNC fails again
Post by mowy »
Hi, it's still worthless to check the "do not show it again" box, I always check it and it reappears.
RSYNC still does not work well, it only makes copies from nas to nas the first time, then it forgets the programming whether it is complete or cumulative, it is unfortunate that in 2023 the issue of copying from nas to nas does not work well.
versiones 4.2.32 y 4.2.40 FIX IT,
Once and for all, if necessary, copy from another competing operating system and do something more professional.
I have two terramasters :ugeek:
Re: RSYNC fails again
If your devices are x.86 models, it is recommended to update to 5.1 latest version.
mowy
Post by mowy »
both ---> F2-221 <----
Please update to TOS 5.1.24 first. Then check if the issue still exists.
mowy
Post by mowy »
WHY i will update my system? The 5.1 have issues with SFTP and user access control.
why the users can see the name of my folders?? or other folders users?? ok cant open this folders why its not professional or yes? folders name of contability, employees... etc its not SECURE.
I understand that if you ask me to update it is because you recognize that version 4 does not work. does it work on 5? sure?????
I want files to be copied from one nas to another nas, from the folder that I indicate, only from the modifications that I make on the server. if I delete 1 file that deletes it from the other, if I create a folder inside that it creates the folder on the other nas. Did you already do this?
powerQ
Singapore
Post by powerQ »
I prefer to keep my system updated.
TMLyy
Post by TMLyy »
{L_BUTTON_AT}mowy
Control Panel》Remote Folder You can use SMB or NFS remote mount function.
mowy
Post by mowy »
I appreciate your help, but it's not a solution, it's a patch.
mowy
Post by mowy »
TMSupport wrote: 10 Mar 2023, 16:43 Please update to TOS 5.1.24 first. Then check if the issue still exists.
You are in the support tell me if it works well. Well, I already tried version 5 on one of the nas and it had more bugs than version 4, pay a beta tester to fix bugs and don't use the final client.
I put hope in your brand, to help and not use the "famous" brands and, you ask me to check for me if version 5.1 no longer has bugs? Do you think I'm an Apple fanboy that I don't care about failures?
I bought two terramasters for the company and I am responsible, now my boss ask me for explanations of the problems.
As Rsync works well in our lab, we do not know why it does not work in your environment. So we need to you try a different version.
Return to “File Services”
