[Wizarr] Automatic user invitation system for Plex, Jellyfin and Emby
About: https://github.com/Wizarrrr/wizarr
Category:
Applicable TOS5: 5.1.12 or later versions
App download: https://tmnascommunity.eu/download/wizarr
Required packages:
Python310
TOS4: http(s)://yournasip:port/modules/Wizarr/www
TOS5: click on Support & Help from app description inside the App Center
About:
Wizarr is a automatic user invitation system for Plex, Jellyfin and Emby. Create a unique link and share it to a user and they will automatically be invited to your Media Server! They will even be guided to download the clients and instructions on how to use your requests software!
Major Features Include:
Automatic Invitation to your Media Server (Plex, Jellyfin, Emby...)
Secured invitation environment
Plug and Play SSO Support*
Multi-tiered Invitations
Duration for membership
Guide user on how to download Plex client
Requests Integration: Guide users on how to request Movies (Overseerr, Ombi...)
Discord Server Integration: Invite users to your Discord Server
Customizable: Add any Custom HTML
ChillZone
Re: [Wizarr] Automatic user invitation system for Plex, Jellyfin and Emby
Post by ChillZone »
I am trying to install Jellyfin on TOS 5.1.33 and I installed Jellyfin fine, then I installed ffmpeg51 fine,
then I installed ModBase1 but it is saying 'ModBase1 is not available in PATH' - I tried clicking the button 'Add in Path' but nothing happens. I also tried going to the link of the forum post which is mentioned in ModBase1 and also tried to follow the WebGUI link (http(s)://yournasip:port/modules/ModBase1/www) and it says 404 Not Found. If I try the port mentioned in Jellyfin App, then it says 'Unable to find the specified file.'
Please help!
