Plex update failed
Plex update failed
Hello, on my F5-221 (with TOS 4.2.40), i run Plex (1.29.0.62244). Plex notifies me of an update (1.31.1.6733), but impossible to manually install it (TOS says "incorrect file" during installation). Perhaps this update is only for TOS 5 ? Or something is wrong in my configuration (even if Plex run perfectly with 1.29.0.62224) ? Thanks in advance.
- crisisacting
- Silver Member
Re: Plex update failed
{L_BUTTON_AT}JJKK33
Choose the one that doesn't have TOS 5 in brackets in the drop-down menu @ https://www.plex.tv/media-server-downlo ... dia-server; Intel ×64 packageRe: Plex update failed
{L_BUTTON_AT}JJKK33
Thanks for your reply ! I check download, but I got the right package, seems to be another trouble. This is not critical as long as the old release run perfectly. Regards.crisisacting wrote: ↑28 Feb 2023, 04:55 Choose the one that doesn't have TOS 5 in brackets in the drop-down menu @ https://www.plex.tv/media-server-downlo ... dia-server; Intel ×64 package
Maybe you can try to change the system language for installation.
