Plex, Permissions, TOS 5.0, F2-420
g3org1
Post by g3org1 »
Hello there,
I have some issues after updating to TOS 5.0.
When I download film or serial and put it in share folder it everytime do not apper in Plex. I figured out it has problem with permissions first time and placed for all users and groups full access. But for each new it change the permission back and I have to log and give again.
I try "Permissions are inherited...." and "Replace the permissons of all..." but it is not working correctly.
Please tell me where is my mistake?
Re: Plex, Permissions, TOS 5.0, F2-420
Which TOS version is installed?
How did you transfer the files?
g3org1
Post by g3org1 »
Dear " TMSupport"
Did you even read my post and title???
The correct TOS version is: 5.0.176-00227.
Files are downloaded through qBittorent.
We will verify it.
g3org1
Post by g3org1 »
Any update or still verifying?
crisisacting
Post by crisisacting »
g3org1 wrote: ↑28 Feb 2023, 03:42 Any update or still verifying?
In another thread on the forum, they mentioned a non-beta 5.1 build coming soon, so if it's fixed, it should be part of that release.
g3org1
Post by g3org1 »
Actually it worked, thanks a lot man.
TOS 5.1.24 fixed the issue.
Return to “Privileges”
