What's the trouble with https://tnas.link/ ?
EgorA
Post by EgorA »
Hi!
It says ERR_SSL_PROTOCOL_ERROR
TNAS mobile also doesn't work.
F4-423
TWlhq
Re: What's the trouble with https://tnas.link/ ?
Post by TWlhq »
{L_BUTTON_AT}EgorA
What is your TOS system version? We will verify this.
EgorA
Post by EgorA »
{L_BUTTON_AT}EgorA
TWlhq wrote: 21 Feb 2023, 23:45 What is your TOS system version? We will verify this.
5.1.22
F4-423
AMartinelli
Post by AMartinelli »
Hi, I have this error as well on TNAS F2-210, version 4.1.32-2008031214
If I try to login to https://tnas-xxxxx...xxxxx.tnas.link...
  • From Firefox 110.0 I have a SSL_ERROR_UNSUPPORTED_VERSION error. The detail says "This website does not support protocol TLS 1.2, which is the minimum version supported by Firefox"
  • On Edge 110.0.1587.50, similarly, I have the following error: "The connection for this site is not secure ....tnas.link uses an unsupported protocol.
    ERR_SSL_VERSION_OR_CIPHER_MISMATCH. The client and server don't support a common SSL protocol version or cipher suite."
Could you please verify?
nachoalja
Post by nachoalja »
Hello, I have the same problem.
My version is 5.0.176-00227
My Tnas is F2-221
nachoalja
Post by nachoalja »
Hello again.
I have solved changing the to global server, not european that it was the recomended.
Return to “Network”
