Failed to enable WebDav on https
manutede
Post by manutede »
Hi!
When I try to enable the webdav service on https with port 474 I get the message "Configuration Saved!" but, in fact, the webdav setting will not stay 'ticked' and the service remains deactivated. The same happens from the services menu. I tried to change port and certificate, i used differents browsers and cleaned cache but nothing. The service starts on http but is not a solution. Use a VPN is not a solution too. The service worked until some time ago and i didn't change anyfing on my configuration.
I'm using a F-221 NAS and TOS Ver. 5.0.176
Please help me.
Thanks.
TMlinda
Re: Failed to enable WebDav on https
Post by TMlinda »
{L_BUTTON_AT}manutede
Have you added or modified the certificate of the WebDAV service?
manutede
Post by manutede »
TMwuu wrote: ↑20 Feb 2023, 20:30 Have you added or modified the certificate of the WebDAV service?
Yes, i did. I had to replace the certificate some week ago because a changed CA.
TMlinda
Post by TMlinda »
You need to replace the certificate you used before.
manutede
Post by manutede »
Resolved. I've to edit the /etc/webdav_conf.ini file. The io setup menu didn't changed anything.
Return to “File Services”
