I have had my TNAS F4-210 for well over a year, and now when I log into it, it takes me to an initialization screen. Why?
I filled out the info to initialize and it says it will erase everything on the hard drives!!!
The whole point of having a 4 drive RAID is for redundancy and now I'm being told it needs to reset and lose everything? WTF?
Log into my TNAS and it takes me to an initialization screen
Re: Log into my TNAS and it takes me to an initialization screen
For some additional context ... I recently ran an update a TOS system update in the TOS Control Panel. After it rebooted, when I tried to login, the screen looked like gibberish.
I only updated TOS because I had tried to update an APP, and the update failed. When the App update failed, there was no log file, and the app itself was removed, but I was unable to re-install the App. So I thought I would check for System Updates.
So .. after all that, I let the unit sit for awhile. When I restated it, I am redirected to the Wizard screen where it tells me the following ...
"Warning
This operation will delete data on the hard drives! Are you sure you want to continue?"
"Warning
Figured it out myself thanks to another users post in this forum.
Getting really tired of this amateur software system. Fortunately I'll never buy another one of these again.
Your file system could be corrupted because of some reasons. To know more...
Can you tell me the fix for this. I had a power cut and I'm now unable to log in and get sent to the setup wizard.
- mcheaiteli
I have the F5-422 I was transferring data and a power cut happened.
When I tried to turn on everything again TerraMaster acts as if its the first time im using it and is asking to format everything for my pool to exist.
How can I get my JBOD set back?
- mcheaiteli
{L_BUTTON_AT}jason_t
Regarding the solution you found to remount the RAID you had,
would you share your solution?
I was transfering data and got a powercut when I turned it back on the JBOD I had was unmounted and im trying to recover it.
Thank you in advance.
{L_BUTTON_AT}mcheaiteli
Please generate and download the log report in TOS > Technical Support > Problem Report, and then send it to suport team mail box as a network disk sharing link for analysis.
- mcheaiteli
I do not have access to the TOS,
I only have access to the TNAS PC app,
When I try to access the server it takes me to a page that wants me to re-initialise my pool I got to the page of "Warning" Find photos attached. (thats where I stopped in fear of getting data formated)
I am trying to get to the JBOD pool that I had already created and used in the past.
Also when I use the Terminal and use some of the codes I found in previous posts this is what I get:
Last login: Tue Jul 11 11:39:52 on ttys000
mcheaiteli@192 ~ % Last login: Mon Sep 13 09:55:15 on console
adminTWMtekiiMac:~ admintwm$ ssh -p 9222 admin@10.18.15.123
The authenticity of host '[10.18.15.123]:9222 ([10.18.15.123]:9222)' can't be established.
RSA key fingerprint is d4:29:f3:57:ef89:2a:fa:21:62:87:86:9e:0d:ae.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '[10.18.15.123]:9222' (RSA) to the list of known hosts.
admin@10.18.15.123's password:
Welcome to TNAS
-bash: ulimit: open files: cannot modify limit: Operation not permitted
admin@TNAS-????:~$ cd /
admin@TNAS-????:/$ sudo -i
Password:
Welcome to TNAS
root@TNAS-????:~#
mcheaiteli console Tue Jul 11 11:08 still logged in
mcheaiteli console Mon Jul 10 11:27 - 20:25 (08:58)
mcheaiteli console Sun Jul 9 18:31 - 23:18 (04:47)
mcheaiteli console Fri Jul 7 15:25 - 15:50 (00:25)
mcheaiteli console Thu Jul 6 22:14 - 14:42 (16:27)
mcheaiteli console Thu Jul 6 13:15 - 16:54 (03:38)
mcheaiteli console Wed Jul 5 19:25 - 19:37 (00:11)
mcheaiteli console Wed Jul 5 14:30 - 18:05 (03:34)
mcheaiteli console Sun Jul 2 11:40 - 11:46 (00:06)
mcheaiteli console Sun Jul 2 10:39 - 11:05 (00:26)
mcheaiteli console Sat Jul 1 21:37 - 01:19 (03:41)
mcheaiteli console Fri Jun 30 19:13 - 19:28 (00:15)
mcheaiteli console Fri Jun 30 10:42 - 11:40 (00:58)
mcheaiteli console Fri Jun 30 09:07 - 09:28 (00:21)
mcheaiteli console Thu Jun 29 10:21 - 18:34 (08:13)
mcheaiteli console Tue Jun 27 15:20 - 15:39 (00:18)
mcheaiteli console Tue Jun 27 08:38 - 15:19 (06:41)
mcheaiteli console Mon Jun 26 20:01 - 21:30 (01:29)
mcheaiteli console Mon Jun 26 15:30 - 17:20 (01:50)
root console Mon Jun 26 15:25 - shutdown (00:02)
mcheaiteli console Sun Jun 25 10:06 - 15:25 (1+05:19)
mcheaiteli console Sat Jun 17 13:15 - 14:00 (00:44)
mcheaiteli console Fri Jun 16 12:46 - 13:07 (00:21)
mcheaiteli console Thu Jun 15 17:23 - 00:46 (07:22)
mcheaiteli console Thu Jun 15 14:38 - 17:23 (02:44)
mcheaiteli console Thu Jun 15 14:27 - 14:35 (00:07)
mcheaiteli console Thu Jun 15 12:11 - 14:27 (02:15)
mcheaiteli console Wed Jun 14 10:12 - 12:53 (02:40)
mcheaiteli console Wed Jun 14 08:52 - 10:11 (01:19)
mcheaiteli console Wed Jun 14 08:02 - 08:51 (00:48)
mcheaiteli console Tue Jun 13 17:55 - 17:58 (00:03)
mcheaiteli console Tue Jun 13 15:43 - 17:53 (02:10)
mcheaiteli console Tue Jun 13 10:41 - 12:27 (01:45)
mcheaiteli console Mon Jun 12 23:37 - 00:36 (00:59)
mcheaiteli console Mon Jun 12 10:33 - 15:17 (04:44)
mcheaiteli console Fri Jun 9 19:06 - 19:31 (00:25)
mcheaiteli console Fri Jun 9 17:36 - 18:21 (00:45)
mcheaiteli console Fri Jun 9 09:07 - 10:51 (01:44)
mcheaiteli console Thu Jun 8 10:47 - 20:42 (09:55)
mcheaiteli console Wed Jun 7 14:45 - 18:32 (03:46)
mcheaiteli console Tue Jun 6 18:05 - 20:12 (02:07)
mcheaiteli console Tue Jun 6 14:57 - 18:05 (03:07)
mcheaiteli console Mon Jun 5 19:00 - 19:01 (00:00)
mcheaiteli console Mon Jun 5 14:32 - 19:00 (04:27)
mcheaiteli console Mon Jun 5 13:38 - 14:19 (00:41)
mcheaiteli console Mon Jun 5 12:01 - 13:37 (01:36)
mcheaiteli console Sat Jun 3 09:58 - 10:15 (00:16)
mcheaiteli console Fri Jun 2 15:30 - 15:36 (00:05)
mcheaiteli console Fri Jun 2 13:57 - 15:22 (01:25)
root console Fri Jun 2 13:52 - shutdown (00:02)
mcheaiteli console Fri Jun 2 09:56 - 13:52 (03:56)
mcheaiteli console Fri Jun 2 09:48 - 09:55 (00:07)
mcheaiteli console Fri Jun 2 09:37 - 09:47 (00:10)
mcheaiteli console Thu Jun 1 23:16 - 09:36 (10:19)
mcheaiteli console Thu Jun 1 23:06 - 23:16 (00:09)
mcheaiteli console Thu Jun 1 17:28 - 23:04 (05:35)
mcheaiteli console Thu Jun 1 17:02 - 17:28 (00:25)
mcheaiteli console Thu Jun 1 15:15 - 17:02 (01:46)
mcheaiteli console Fri May 19 21:43 - 23:17 (01:33)
mcheaiteli console Fri May 19 15:41 - 21:43 (06:01)
mcheaiteli console Fri May 19 13:41 - 15:40 (01:59)
mcheaiteli console Fri May 19 13:00 - 13:41 (00:40)
mcheaiteli console Thu May 18 21:17 - 22:59 (01:41)
mcheaiteli console Wed May 17 23:14 - 10:55 (11:40)
mcheaiteli console Wed May 17 19:24 - 23:13 (03:48)
mcheaiteli console Wed May 17 13:48 - 19:24 (05:35)
mcheaiteli console Tue May 9 08:30 - 08:32 (00:02)
mcheaiteli console Mon May 8 23:44 - 23:45 (00:00)
mcheaiteli console Mon May 8 19:24 - 23:43 (04:19)
mcheaiteli console Mon May 8 16:21 - 16:44 (00:23)
mcheaiteli console Thu Apr 20 19:01 - 06:56 (11:55)
mcheaiteli console Thu Apr 20 13:18 - 14:20 (01:02)
mcheaiteli console Thu Apr 20 07:22 - 07:26 (00:03)
root console Thu Apr 20 07:12 - shutdown (00:02)
mcheaiteli console Wed Apr 19 21:08 - 07:12 (10:04)
mcheaiteli console Tue Apr 18 09:28 - 09:48 (00:20)
mcheaiteli console Mon Apr 17 11:39 - 12:43 (01:04)
mcheaiteli console Mon Apr 17 10:07 - 10:41 (00:33)
mcheaiteli console Sun Apr 16 19:04 - 00:19 (05:15)
mcheaiteli console Fri Apr 14 13:44 - 16:43 (02:58)
mcheaiteli console Thu Apr 13 11:29 - 10:06 (22:37)
mcheaiteli console Wed Apr 12 14:50 - 22:53 (08:03)
mcheaiteli console Tue Apr 11 19:53 - 00:07 (04:14)
mcheaiteli console Tue Apr 11 13:20 - 13:25 (00:04)
mcheaiteli console Thu Mar 23 12:54 - 23:44 (10:49)
mcheaiteli console Fri Mar 10 08:09 - 08:22 (00:12)
mcheaiteli console Tue Mar 7 16:35 - 20:38 (04:02)
root console Tue Mar 7 16:30 - shutdown (00:02)
mcheaiteli console Tue Mar 7 14:54 - 16:30 (01:36)
mcheaiteli console Mon Mar 6 16:04 - 18:39 (02:34)
mcheaiteli console Fri Mar 3 10:54 - 10:59 (00:05)
mcheaiteli console Sun Feb 26 05:19 - 09:57 (5+04:38)
mcheaiteli console Fri Feb 24 20:10 - 05:17 (1+09:07)
mcheaiteli console Fri Feb 24 12:17 - 16:25 (04:08)
mcheaiteli console Thu Feb 23 09:58 - 21:45 (11:46)
mcheaiteli console Wed Feb 22 15:06 - 22:11 (07:04)
mcheaiteli console Tue Feb 21 10:01 - 10:08 (00:07)
mcheaiteli console Tue Feb 21 08:21 - 09:14 (00:53)
mcheaiteli console Mon Feb 20 07:47 - 21:15 (13:27)
mcheaiteli console Fri Feb 17 05:42 - 23:50 (2+18:07)
mcheaiteli console Tue Feb 14 19:47 - 22:01 (1+02:14)
mcheaiteli console Mon Feb 13 19:06 - 19:29 (00:22)
mcheaiteli console Mon Feb 13 14:55 - 14:58 (00:03)
mcheaiteli console Mon Feb 13 13:28 - 13:37 (00:09)
mcheaiteli console Sun Feb 12 22:24 - 22:38 (00:14)
mcheaiteli console Sun Feb 12 10:04 - 22:23 (12:19)
mcheaiteli console Sat Feb 11 20:29 - 23:40 (03:10)
mcheaiteli console Fri Feb 10 21:46 - 23:42 (01:56)
mcheaiteli console Thu Feb 9 20:38 - 22:35 (01:57)
mcheaiteli console Wed Feb 8 21:23 - 21:32 (00:09)
mcheaiteli console Tue Feb 7 21:19 - 22:43 (01:24)
mcheaiteli console Mon Feb 6 19:47 - 23:17 (03:29)
mcheaiteli console Fri Feb 3 17:25 - 17:35 (00:09)
mcheaiteli console Thu Feb 2 09:43 - 17:24 (1+07:40)
mcheaiteli console Thu Jan 26 18:48 - 21:31 (02:42)
mcheaiteli console Fri Jan 20 21:58 - 22:06 (00:08)
mcheaiteli console Sun Jan 8 22:04 - 00:46 (02:41)
mcheaiteli console Sun Dec 25 21:08 - 21:48 (00:40)
mcheaiteli console Mon Dec 12 20:57 - 21:20 (00:22)
mcheaiteli console Mon Dec 12 10:58 - 11:26 (00:28)
mcheaiteli console Sat Dec 10 21:01 - 22:30 (01:28)
mcheaiteli console Sat Dec 10 12:37 - 12:51 (00:14)
mcheaiteli console Thu Dec 8 15:56 - 10:52 (1+18:56)
mcheaiteli console Thu Dec 8 09:50 - 10:06 (00:16)
mcheaiteli console Wed Dec 7 23:41 - 01:07 (01:25)
mcheaiteli console Wed Dec 7 14:49 - 18:46 (03:57)
mcheaiteli console Mon Dec 5 09:20 - 00:25 (1+15:05)
mcheaiteli console Sun Dec 4 20:34 - 23:17 (02:43)
mcheaiteli console Sat Dec 3 19:03 - 22:51 (03:48)
mcheaiteli console Thu Dec 1 15:10 - 17:07 (01:56)
wtmp begins Thu Dec 1 15:20
zsh: command not found: adminTWMtekiiMac:~
zsh: no matches found: cant be established.\nRSA key fingerprint is d4:29:f3:57:ef89:2a:fa:21:62:87:86:9e:0d:ae.\nAre you sure you want to continue connecting (yes/no)? yes\nWarning: Permanently added [10.18.15.123]:9222 (RSA) to the list of known hosts.\nadmin@10.18.15.123s
zsh: command not found: Welcome
zsh: command not found: -bash:
zsh: no matches found: admin@TNAS-????:~$
mcheaiteli@192 ~ %
Welcome to TNAS
Password:
Welcome to TNAS
root@TNAS-????:~#
mcheaiteli@192 ~ %
Please contact customer service in the bottom right corner of Official website or support team mailbox to schedule a time for engineers to remotely troubleshoot issues for you.
