Terramaster F2-210 - disconnecting and not reconnecting
Claymore61
Post by Claymore61 »
Ok - I see masses of reports on this, yet no matter what I do it keeps reverting.
There must be a solid fix for this or its going in the bin.
My F2-210 stays connected for an inconsistent time, then I cant get access.
Ive tried the a fixed IP , done.
Ive updated the windows system to have SMB 1.0 ( and all ) on
firewall on and off
Ive switched it on and off, unplugged the power, waited and plugged it back in again.
Sky router checked ok
hard drives are red series
One of the only things that works is unplugging the LAN cable from the router, plugging it into my desktop, then TNAS finds it. But I cannot log onto it with the TOS, or find it in windows explorer
I then unplug the network cable, plug it back into my router and BANG - access granted.
Any ideas before I start moving all my files and binning this thing.
Re: Terramaster F2-210 - disconnecting and not reconnecting
How long have you been using this device? when does this issue start to appear?
Claymore61
I’ve had it for a year odd ( itnink) and it’s kinda always been happening.
I’ve searched and searched online and have found some resolutions now and again, but surely I should be able to access a network drive without all this fuss.
Just hitting frustration point now.
Not sure what could be the issue, what solution you found?
Claymore61
Just what I said above.
Plug it directly into the PC, then unplug and plug back into the router
Return to “Network”
