Hi All!
Is it good idea to upgrade J3455 to Intel Pentium J4205, the same BGA1296, but ~ 13% better. (up to 2.6 GHz).
Yes, I'm aware of the warranty cancellation.
CPU upgrade F4-422
- crisisacting
- Silver Member
Re: CPU upgrade F4-422
As long as the microcode is within the motherboard UEFI BIOS & you have the skills to replace the soldered down Celeron with that Pentium, sure.
With such skills, you can do much more than that.
