next cloud out of date and errors
epsilonion
Post by epsilonion »
I thought I would try nextcloud as I have it on a VM.
A few issues I noticed:
Out of date
Errors straight after installing include:
The PHP memory limit is below the recommended value of 512MB.
Your data directory and files are probably accessible from the internet. The .htaccess file is not working. It is strongly recommended that you configure your web server so that the data directory is no longer accessible, or move the data directory outside the web server document root.
Some app directories are owned by a different user than the web server one. This may be the case if apps have been installed manually. Check the permissions of the following app directories:
/Volume1/@apps/Nextcloud/webui/apps/accessibility
/Volume1/@apps/Nextcloud/webui/apps/admin_audit
/Volume1/@apps/Nextcloud/webui/apps/cloud_federation_api
/Volume1/@apps/Nextcloud/webui/apps/comments
/Volume1/@apps/Nextcloud/webui/apps/contactsinteraction
/Volume1/@apps/Nextcloud/webui/apps/dashboard
/Volume1/@apps/Nextcloud/webui/apps/dav
/Volume1/@apps/Nextcloud/webui/apps/encryption
/Volume1/@apps/Nextcloud/webui/apps/federatedfilesharing
/Volume1/@apps/Nextcloud/webui/apps/federation
/Volume1/@apps/Nextcloud/webui/apps/files
/Volume1/@apps/Nextcloud/webui/apps/files_external
/Volume1/@apps/Nextcloud/webui/apps/files_sharing
/Volume1/@apps/Nextcloud/webui/apps/files_trashbin
/Volume1/@apps/Nextcloud/webui/apps/files_versions
/Volume1/@apps/Nextcloud/webui/apps/lookup_server_connector
/Volume1/@apps/Nextcloud/webui/apps/oauth2
/Volume1/@apps/Nextcloud/webui/apps/provisioning_api
/Volume1/@apps/Nextcloud/webui/apps/settings
/Volume1/@apps/Nextcloud/webui/apps/sharebymail
/Volume1/@apps/Nextcloud/webui/apps/systemtags
/Volume1/@apps/Nextcloud/webui/apps/testing
/Volume1/@apps/Nextcloud/webui/apps/theming
/Volume1/@apps/Nextcloud/webui/apps/twofactor_backupcodes
/Volume1/@apps/Nextcloud/webui/apps/updatenotification
/Volume1/@apps/Nextcloud/webui/apps/user_ldap
/Volume1/@apps/Nextcloud/webui/apps/user_status
/Volume1/@apps/Nextcloud/webui/apps/weather_status
/Volume1/@apps/Nextcloud/webui/apps/workflowengine
The "X-Content-Type-Options" HTTP header is not set to "nosniff". This is a potential security or privacy risk, as it is recommended to adjust this setting accordingly.
The "X-Frame-Options" HTTP header is not set to "SAMEORIGIN". This is a potential security or privacy risk, as it is recommended to adjust this setting accordingly.
The "Strict-Transport-Security" HTTP header is not set to at least "15552000" seconds. For enhanced security, it is recommended to enable HSTS as described in the security tips ↗.
Your web server is not properly set up to resolve "/.well-known/webfinger". Further information can be found in the documentation ↗.
Your web server is not properly set up to resolve "/.well-known/nodeinfo". Further information can be found in the documentation ↗.
Your web server is not properly set up to resolve "/.well-known/caldav". Further information can be found in the documentation ↗.
Your web server is not properly set up to resolve "/.well-known/carddav". Further information can be found in the documentation ↗.
Return to “Others”
