How do I add new HDD
GoldenSpider
Post by GoldenSpider »
This may seem like a stupid question, but I genuinely can't figure it out
I just bought and installed a new HDD as my current HDD is getting full
But I can't for the life of me figure out how to add the HDD in TOS
I can set it up as a new storage pool and volume, but when I try to edit my current storage pool or volume to have it add the second HDD it does not give any option for that
my previous HDD was a 6TB one and my new one is a 14TB one
I do not want to RAID or anything like that. I want to combine the two of them so I have a useable total of 20TB
I dont NEED to set up the new HDD as an extension to the volume/storage pool, but even still when I then set up the new HDD as a new storage pool/volume I can't figure out how to actually access the new volume or storage pool to add files to it, or folders, etc. TOS is "locked" into Volume 1 and I can't figure out a way to get out of it
Any help is most appreciated
Re: How do I add new HDD
If you currently create single-disk mode with one hard drive, adding new hard drives to single-disk mode is not supported.
You can create a new storage pool and volume with the new hard disk, and then create shared folders on the volume to store data.
GoldenSpider
How do I do that, as mentioned before. i can not get file explorer to get into Volume 2 to create any folders or move any files
GoldenSpider
In trying to figure this out I also Accidentally set up RAID on the drives, is there a way to remove RAID without deleting the volume/pool entirely and losing all my Data?
GoldenSpider wrote: 09 Feb 2023, 01:39 How do I do that, as mentioned before. i can not get file explorer to get into Volume 2 to create any folders or move any files
Please go to Control Panel - Shared Folder to create a shared folder belonging to volume 2.
GoldenSpider wrote: 09 Feb 2023, 01:55 In trying to figure this out I also Accidentally set up RAID on the drives, is there a way to remove RAID without deleting the volume/pool entirely and losing all my Data?
You can only backup data first.
Return to “File Services”
