After change of ip, no more access and not detected by tnas
FL4k
Post by FL4k »
I have recently purchased a firewall, which makes me manually change ip addresses, gateways etc...
But when I configure my NAS it is not detected anywhere and I can't access it.
Default ip without firewall : 192.168.1.17-18 After : 192.168.100.17-18
netmask 255.255.255.0
Gateway before: 192.168.1.1 After: 192.168.100.1
I really need help.
If anyones haves an ideas
sae24
Re: After change of ip, no more access and not detected by tnas
Post by sae24 »
Hi!
Looks like U need set address by DHCP, than, when nas will got correct gateway U may set ip manually. Try to disable firewall for a time, in network settings select DHCP.....
Return to “Network”
