No Apps
Transmission, qBittorrent, Aria 2 download applications
EdJ
No Apps
Post by EdJ »
I have no Apps available for download on the desktop. F2-210. Tried the chat yesterday and got told to try again today, but it's been like this since I got up and running a week ago TOS 4.1.32. Any advice?
titanrx8
Re: No Apps
Post by titanrx8 »
Do you have a firewall blocking www.tnas.online ?
Re: No Apps
{L_BUTTON_AT}EdJ
Your system is out of date so much, please update your system and try again.
EdJ
Re: No Apps
Post by EdJ »
Have tried that and it wont load, just getting the loading bar and now have no access to my NAS, What's next?
Re: No Apps
{L_BUTTON_AT}EdJ
The latest version of TOS for your model is 4.2.41. Did you follow this guide to update your TOS? viewtopic.php?f=28&t=4117 Just because your system is quite out of date, you need to follow this guideline to update your system step by step. viewtopic.php?f=76&t=1064
danialgurman
Re: No Apps
Post by danialgurman »
I came here to ask the same question. And no, resetting the app does NOT work. All I see is the load bar..
"Knowledge is power." master number 11
FrankHopkins
Re: No Apps
Post by FrankHopkins »
danialgurman wrote: 27 May 2023, 23:51 I came here to ask the same question. And no, resetting the app does NOT work. All I see is the load bar..
You can install Mod APK, I think it will work
Return to “Download”
