[ OwnTone ] Audio media server
About: https://owntone.github.io/owntone-server
Category: Multimedia
Applicable TOS4: 4.1.27 or later versions - on request
Applicable TOS5: 5.1.12 or later versions
App download: https://tmnascommunity.eu/download/owntone
Required packages:
ModBase1 > 1.00.13
Make sure to give media group access to you music folder and edit the directory path in owncloud.conf
TOS4: http(s)://yournasip:port/modules/OwnTone/www
TOS5: click on Support & Help from app description inside the App Center
About
OwnTone is an open source (audio) media server for GNU/Linux, FreeBSD and MacOS.
It allows sharing and streaming your media library to iTunes (DAAP1), Roku (RSP), AirPlay devices (multiroom), Chromecast and also supports local playback.
You can control OwnTone via its web interface, Apple Remote (and compatible DAAP/DACP clients), MPD clients or via its JSON API.
Besides serving your local music, podcast and audiobook media files, OwnTone supports internet radios and Spotify (requires Spotify premium account).
zarumpus
Re: [ OwnTone ] Audio media server
Post by zarumpus »
You've done a good job! Please update the application for TOS6
zarumpus
Post by zarumpus »
Please update the app!
