An App Center that actually works would be a nice feature
TerraNAS92
Post by TerraNAS92 »
Running TerraMaster F2-422 with TOS 4.2.40, I can't install any app from the officail App center.
The launcher starts, and is stuck at "Installing : 0%".
That is of course a serious limitation to the use of the NAS...
I know I can download the apps from the website, but I think this is a basic feature that should work :-(
Regards.
Re: An App Center that actually works would be a nice feature
seems your TNAS failed to download the app from the server, please check if your network gateway and DNS settings are correct, any firewall blocked the link?
TerraNAS92
Thanks for taking time to reply and try to help me out of this problems :-)
The problem is : there are 2 Ethernet interfaces used.
One is purely local and hooked up to computer directly.
The other one is connected to internet.
The default interface was the one that was used locally.
I switched the default interface.
Problem solved :-)
Regards.
FRED
{L_BUTTON_AT}TerraNAS92
Great to hear you found your way out.
