My system (T12-423 running TOS 5.0.176) is now showing an alert that the terra-master.com certificate has expired.
How do I renew the certificate?
Terra-master.com certificate has expired
Re: Terra-master.com certificate has expired
I also have this alert, guess over CNY everything breaks lol
The fix is unfortunately:
enable TNAS.online under remote access from the desktop, this would expose the nas login to attack vector if unlucky
Hi, you can simply update "terra-master.com" certificate through the "Update" button in the certificate management interface.
- epsilonion
I was wondering about this aswell, wouldn't it be better to have it auto update?
Sorry to be dense, but I have this problem as well.
Do I update the certificate in Windows or in the TerraMaster user interface?
Whichever method please explain exactly how I do this since I can't figure it out. Thanks.
I can see the Certificate in the TM Security application, and it indicates it expired 15 days ago. I have been having problems about this long. However when I click on the Certificate I do not see a means to update it. Any help appreciated. Thanks.
Select the expired certificate on TOS > Control panel > security > certificate, and click on the "Update" button.
- ChrisRobots
Having the same issue - There's no update button... Can anyone help me out here? Cheers
- crisisacting
- Silver Member
What version of TOS are you running?ChrisRobots wrote: ↑27 Feb 2023, 23:48 Having the same issue - There's no update button... Can anyone help me out here? Cheers
The newer build all have an update option above the 3 certificates which becomes clickable when you individually click eligible certificates.
