Hi there,
Is there a way to install docker compose (https://docs.docker.com/compose/install ... ll-options) on TOS?
Thanks!
docker compose install
Re: docker compose install
Hi jack,
Currently this features is not supported. But if you can tell us how this feature will benefit to most of TNAS users, we may consider to implement it.
Hi, this would be a good feature for us to create a new docker and use it in the docker application. As we create new web application we can do a docker compose and deploy directly in the docker.
OK, we will discuss your demand internally, will keep you updated.
I second this request, docker-compose would be a great addition and competitors (QNAP) have it installed together with docker directly.
Either give us a curl command on the bash or a small installation package, shouldnt be too hard. thanks
Hi, your demand has been forwarded to our tech team. But this request does not have good priority at this moment. Will keep you updated.
Hi, is there any update on taking up this small but powerful feature?
It's possible to installed it manually, you only need the linux binary (take a look to https://docs.docker.com/compose/install/) and you can give access other users different than root following https://docs.docker.com/engine/install/ ... stinstall/
Do at your own risk
sports_wook
I'd also like to voice my desire for docker compose. I've run into multiple docker files that don't work properly or can't be installed without docker compose. This is a viral component of docker service. Would GREATLY appreciate this being implemented in a future update.
