System Time Not Correct
jack
Post by jack »
Hey all,
The time on my F2-210 is not correct. It's about 4 mins ahead of correct time. How can I fix it?
Time is set to sync with server (see pic).
Thanks!
Re: System Time Not Correct
Time server auto sync every 24hours. You can click “update” to sync manually.
jack
Post by jack »
Thx!
Achim.Z.
Post by Achim.Z. »
is there a way to set my domain internal time server?
regards
Achim
iPeriod
Post by iPeriod »
I posted this fix viewtopic.php?f=22&t=412 in another (older) post. It should fix your issue as long as you don't apply another NTP change from the GUI.
I also forgot to mention it would be a good idea to ensure your local NTP server is pingable and that running 'ntpdate <local NTP>' works for you.
HTH,
i.
