How to turn ON the buzzer ??
rapcat
Post by rapcat »
Hi, which command or binary should I use in TOS4.2.4 to make a sound with the built in speaker ??
Re: How to turn ON the buzzer ??
If your TNAS is x86 architecture, you may find the Buzzer Controllor at TOS>Crontrol Panel>Hardware & Power.
If your TNAS is arm architecture, maybe you can try this user's suggestion:
https://forum.terra-master.com/cn/viewt ... =33&t=2078
rapcat
Post by rapcat »
Thank you, my nas is F4-210 so it's arm. I want to disable the buzzer during power on and power off but keep it working for other things and also make it sound from custom scripts
rapcat
Post by rapcat »
TMzethar wrote: ↑09 Jan 2023, 21:39 If your TNAS is x86 architecture, you may find the Buzzer Controllor at TOS>Crontrol Panel>Hardware & Power.
Thank you very much. I managed to do it with the information in the link you posted. :D
