Migrate data to upgrade HDD
xm41907
Post by xm41907 »
I'm running out of space on one of my two F2-221 bays and would like to upgrade from a 4TB drive to a 16TB drive. My second bay is already occupied, so I can't just copy the data over. If I do the upgrade can I put the old one in a USB enclosure and then transfer the data over to the new HDD from there? My suspicion is that I can't because of the file systems Terramaster uses and that I'll need a different HDD to use as an intermediary during the switch.
crisisacting
Re: Migrate data to upgrade HDD
Post by crisisacting »
xm41907 wrote: 08 Jan 2023, 11:03My suspicion is that I can't because of the file systems Terramaster uses and that I'll need a different HDD to use as an intermediary during the switch.
That's right. The external drive support different file systems then the internal ones used by TOS: https://www.terra-master.com/global/f2- ... nu&mid=276
Moving the data onto a large external drive, cloud storage or backing up to another NAS via rsync would be necessary to increase your storage pool or reinitializing your F2-221.
A backup strategy should be in place regardless if it's important data.
xm41907
Post by xm41907 »
I've recently been compiling all of my various external hard drives onto my NAS and they took more room than I was anticipating, so everything has a backup already, but in various jumbled drives.
