Please help - New to this - SSD Caching
Nesiah
Post by Nesiah »
Got the TM f2-210 - put a Samsung 860 Evo in the second bay to use as cache, and cant seem to figure out how to set it up. Ive been through the forums and googled, but still no luck.
Re: Please help - New to this - SSD Caching
F2-210/F4-210 does not support SSD cache. To use SSD cache feature, you need to order x.86 series models like F2-221/F2-223/F2-423/F4-423.
Nesiah
Post by Nesiah »
TMroy wrote: 08 Jan 2023, 00:42 F2-210/F4-210 does not support SSD cache. To use SSD cache feature, you need to order x.86 series models like F2-221/F2-223/F2-423/F4-423.
Arrrrr thanks!
sae24
Post by sae24 »
Hi, All!
F4-422 also support caching, but U need to take of cover and find hidden plug (SATA) on the right side of back plate. I'm using WD RED SA 500 - 500Gb. After install disk U need to activate cache on it. ~70% of disk will be used.
As bonus, with open cover U may install memory module 4Gb or 8Gb (in mu case it working) KINGSPEC KS1600D3N13508G DDR3L - 8ГБ 1600, SO-DIMM feet well. But on 5.0.176 I can't see that system use additional memory actively.
