qBittorrent beta is released for testing
Transmission, qBittorrent, Aria 2 download applications
Greetings community,
We are excited to introduce qBittorrent 4.1.7 beta, the world's most popular download application, now is online for testing!
To install qBittorrent, go to TOS > Application > Beta.
Applicable models:
220 series: F2-220/F4-220/F5-220
420 series: F2-420/F4-420/F5-420
221 series: F2-221/F4-221/F5-221
421 series: F2-421/F4-421/F5-421
422 series: F2-422/F4-422/F5-422
qBittorrent, an advanced and multi-platform BitTorrent client with a nice Qt user interface as well as a Web UI for remote control and an integrated search engine. qBittorrent aims to meet the needs of most users while using as little CPU and memory as possible.
qBittorrent Features
Polished µTorrent-like User Interface
No Ads
Well-integrated and extensible Search Engine
Simultaneous search in many Torrent search sites
Category-specific search requests (e.g. Books, Music, Software)
RSS feed support with advanced download filters (incl. regex)
Many Bittorrent extensions supported:
Magnet links
Distributed hash table (DHT), peer exchange protocol (PEX), local peer discovery (LSD)
Private torrents
Encrypted connections
and many more...
Remote control through Web user interface, written with AJAX
Nearly identical to the regular GUI
Sequential downloading (Download in order)
Advanced control over torrents, trackers and peers
Torrents queueing and prioritizing
Torrent content selection and prioritizing
Bandwidth scheduler
Torrent creation tool
IP Filtering (eMule & PeerGuardian format compatible)
IPv6 compliant
UPnP / NAT-PMP port forwarding support
Available on all platforms: Windows, Linux, macOS, FreeBSD, OS/2
Available in ~70 languages
Go ahead and try qBittorrent, you won't regret it!
Aleguerro
Re: qBittorrent beta is released for testing
Post by Aleguerro »
Good morning,I have trouble adding search plugins. I go to "Insall a new one" and i copy the URL of the .py file, but the OK button doesn't seem to work at all. Doing the same procedure on the windows Qbittorent program works just fine.
Could you please tell me why?
Thank you
Aleguerro
Post by Aleguerro »
Good morning, After several weeks of good performances, Qbittorrent seems to has stopped working.
I'm experiencing the following issues:
-Opening the app in my desktop I had found the "502 Bad Gateway" message.
- I've tried to unistall the app and then installing it again, but, after the installation, the message "configuring... stopped" appears.
- If I click on the button start button the same message appears.
Is the server down for maintenance reasons or it is just my problem?
Thank you
hades
Post by hades »
Any plans on releasing it to the F2-210?
{L_BUTTON_AT}hades
There are no plans to add this application at the moment.
Rerali
Post by Rerali »
Thanks for adding this to the application store. :D
That said, it has been a while since the initial release. Will we be getting any updates any time soon?
{L_BUTTON_AT}Rerali
We will not consider updating this application until we release TOS 4.3.X.
tasete30
Spain
Post by tasete30 »
I have a problem trying to add search plugins in my f5-221. When i try the ok button doesn't work.
Any tip to add a search plugin?
There may not be an environment for installing the plug-in.
You can try to download Python3 and use the plug-in link that requires a lower version of Python.
tasete30 wrote: ↑30 Mar 2021, 23:36 I have a problem trying to add search plugins in my f5-221. When i try the ok button doesn't work.
Which searh plugin are you trying to add ?
Return to “Download”
