I'm trying to set up a VPN Server on TNAS, and the TOS Help says: "To install VPN Server, go to the TOS App Center, find VPN Server, and then click "Install"." However, when I look in "Applications" I do not see "VPN Server" anywhere. Was VPN Server removed?
Is there file somewhere that I can manually install?
How else could I setup a VPN server on TNAS?
I've tried using containers on docker like wireguard and openvpn but haven't been able to get anything to work.
VPN Server How To
Re: VPN Server How To
Which TOS version did you install?
Can you find other apps in the app center?
- TtimmEwath
Looks like my TOS version is 4.2.40.
There are other apps in the app center, like Docker and Plex Media Server, both of which I was able to successfully install and setup.
Hi! I have the same problem with TOS 4.2.41.
Will this TOS version support VPN connection easier than docker containers?
- sianderson
- Silver Member
if you are using an ARM based nas drive e.g. F2-210 then there is no VPN server it only works on the intel versions e.g. F2-220 etc
i had a quick play with docker but didnt seem to have any joy with it so just accepted that i cant VPN to the NAS, however it does what i needed it to do so still happy enough with it
F2-424 TOS 7.0.0777
F2-423 TOS 7.0.0777
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.0777
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
- CodeHunter
My F2-212 downloads great!
- sianderson
- Silver Member
well thats good however please do note that the F2-212 didnt even exist in 2023 which is the thread you have commented on
the F2-210 doesnt support VPN !!!
F2-424 TOS 7.0.0777
F2-423 TOS 7.0.0777
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.0777
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
