Access Forbidden
Using Web Server, PHP, MySQL, MariaDB.
Archigos
Access Forbidden
Post by Archigos »
I'm running the latest TOS 5.0.176 and have the Webserver 2.2.6 installed. About a week or two I created a folder in the root of the server and put some files in it. When I gave the link to a friend it showed the directory listing of that folder (which is what I wanted), they were able to download the files so I deleted the folder. I have since rebooted the server, but now when I create a folder in the root, no matter what link I give them (for the folder) I get access forbidden. I tried creating an .htaccess file inside that folder with the following:
Options +Indexes
and I get the same error. Just to test it, I tried creating an .htaccess with the same info in the root folder and that changed from showing my page to the same access forbidden error.
Ideally, I do NOT want to deal with .htaccess at all and allow any directory without an index.php to just show the directory listing by default. I have no idea where the httpd.conf file is or any other way to configure the server. Any help would be appreciated.
Re: Access Forbidden
You can edit the permissions of the media user group for this shared folder. If you set open_basedir for php, you can try none instead.
Archigos
Post by Archigos »
I already have the settings you mentioned and nothing changed.
Archigos
Post by Archigos »
Nevermind, I rebooted and it fixed it... (I had just checked the settings you mentioned, changed away from what you said and changed back to make sure they matched and it worked.)
I think the issue came from the fact that the Media group didn't have permissions to Public cause that's the only thing that changed.
:: Sorry, couldn't find an edit for my last post
Archigos
Post by Archigos »
It's done it a few times since... to solve it, I have to Control Panel -> User Group click to edit media click Permissions not change anything and hit Apply and wait... once it's done I can refresh the webpage and have it work.
Return to “Web Server/PHP/MySQL/MariaDB”
