sysSnapShoot space
Supr4
sysSnapShoot space
Post by Supr4 »
Hi, i have a F2-423 and am having some issues with space. I have a full disk used, i've tried to delete some files but still i can get some breathing space and i don't know why.
I Have BTRFS Snapshots disabled (i had it enabled at some point), but there's a folder called sysSnapShoot that lists as having 2.5T used space.
How can i clear this? I have snapshots disabled and snapshot list is empty (on all volumes).
Supr4
Re: sysSnapShoot space
Post by Supr4 »
Its actually both @sysSnapShoot and @snapshot folders:
0 ./public
2.0M ./User
1.1M ./@system
0 ./@apps
268M ./@cache
0 ./@desktop
84K ./@zlog
12G ./DockerData
2.5T ./@sysSnapShoot
0 ./@usb
3.5T ./Media
0 ./@thumbnail
3.6T ./@snapshot
nrapallo
Post by nrapallo »
I recently observed the same thing on my NAS (the @snapshot folder is only about 0.5TB in size) but I suspect the answer will turn out to be the reply to a similar thread here viewtopic.php?p=22521#p22521
-Nick
TNAS F5-221
BIOS/InitBoot MAPL0304V21
Currently on TOS v6.0.650
Supr4
Post by Supr4 »
I saw that. But my snapshot list is showing as empty (even if i enable it), so it cant delete anything.
You can check the file system snapshot in the backup on the TOS desktop.
When you enable file system snapshots, you will be able to see the file system snapshots you took before, and then you can delete them.
Supr4
Post by Supr4 »
I have enabled both Filesystem snapshot and snapshot applications but still the list are empty, cant delete them.
The command 'du' is not suitable for querying the size of btrfs volumes, and the results obtained are wrong.
Please use the following command:
btrfs filesystem usage /Volume1
What is the volume size? Noticed that there is a Media shared folder taking up a lot of storage space.
Supr4
Post by Supr4 »
That Media folder is normal, that's where my files are.
Here's the output of that cmd:
Overall:
Device size: 3.63TiB
Device allocated: 3.63TiB
Device unallocated: 1.00MiB
Device missing: 0.00B
Used: 3.63TiB
Free (estimated): 1.09MiB (min: 1.09MiB)
Data ratio: 1.00
Metadata ratio: 2.00
Global reserve: 16.00MiB (used: 0.00B)
Data,single: Size:3.63TiB, Used:3.63TiB (100.00%)
/dev/mapper/vg0-lv0 3.63TiB
Metadata,DUP: Size:1.00GiB, Used:284.94MiB (27.83%)
/dev/mapper/vg0-lv0 2.00GiB
System,DUP: Size:8.00MiB, Used:512.00KiB (6.25%)
/dev/mapper/vg0-lv0 16.00MiB
Unallocated:
/dev/mapper/vg0-lv0 1.00MiB
The total capacity size of the volume is 3.63T, while the Media folder occupies 3.5T.
Supr4
Post by Supr4 »
I deleted several video files worth >200GB, but still the disk is full. It can't be the recycle bin, because i disabled it.
