NFS doesn't write all records to /etc/exports
freman
Australia
Post by freman »
Hi
I've been having problems ever since I added a second client to my NFS share, took me a little while to get around to sshing in to take a look
As you can see by the screenshot I have 2 clients set up (one was originally read only but for testing I made it rw)
As you can see here there's only one record in /etc/exports
[SuperUser@Store ~]# cat /etc/exports
"/Volume1/Aria2" *(rw,async,crossmnt,insecure_locks,sec=sys,no_root_squash,anonuid=6,anongid=4)
"/Volume1/DockerData" *(rw,async,crossmnt,insecure_locks,sec=sys,no_root_squash,anonuid=6,anongid=4)
"/Volume1/Photos" *(rw,async,crossmnt,insecure_locks,sec=sys,no_root_squash,anonuid=6,anongid=4)
"/Volume1/public" 10.0.0.2(rw,async,crossmnt,insecure_locks,sec=sys,all_squash,anonuid=0,anongid=4)
TMlinda
Re: NFS doesn't write all records to /etc/exports
Post by TMlinda »
{L_BUTTON_AT}freman
Hello, in the TOS5.0 system, only one NFS rule set for the shared folder can be identified, and this problem has been solved in the TOS5.1 system. For this problem, you can choose to set the rule to allow all clients to connect on the TOS5.0 system, or upgrade to the TOS5.1 system.
freman
Australia
Post by freman »
The UI lets you define multiple.
I'm not sure why you'd need a beta upgrade, surely this feature would be backportable.
Return to “File Services”
