Media Indexing all the time
thurgt
Post by thurgt »
I am constantly getting notices that my system is sluggish and when I check its due to media indexing. Nothing is changing on any location that should be indexed. I have an FTP upload to a folder but that folder system is removed from indexing so I can only assume that removing an item from indexing isn't working currently.
Is anyone else seeing this?
thurgt
Re: Media Indexing all the time
Post by thurgt »
Another clue this may be the case is when accessing Photos on the TNAS Mobile 3 app I can see photos from the folder that shouldn't be being indexed.
Which TOS version are you using? Please update it to the latest.
If the indexed data is incorrect, you can rebuild the index.
thurgt
Post by thurgt »
TMSupport wrote: ↑21 Dec 2022, 16:20 Which TOS version are you using? Please update it to the latest.
Running TOS 5.0.176-00227 and system shows its the current version.
How do you rebuild the index? I only see options to turn it on and off.
TMnight
Post by TMnight »
Rebuild index in Control Panel》Network Service》Media Index
Return to “System Resources”
