ID TNAS is in use I can not activate
ManelN7
Post by ManelN7 »
Activate my ID on a new NAS F4. Previously I had deactivated the previous nas in case there was conflict.
My previous nas is the F5 221 and I'm seeing if I migrate to an F4 423. I have been able to activate it in the F4, I see that if it works but I can not reactivate the F5.
I deactivate the F4 to be able to use the F5 again but it already tells me that it is in use ID TNAS is un use!!
Result: I can't access
What should I do?
TMnight
Re: ID TNAS is in use I can not activate
Post by TMnight »
You can try to start up F5 when there is no hard disk. Can you search IP through TNAS PC?
Return to “Network”
