Moving OS/System, All Apps to SSD?
tres
Post by tres »
Hey guys,
I want to move the whole system and all apps, processes etc. to my installed SSD. This way I can keep the large (and more noisy) TRAID for storage and streaming only and let it sleep when I don't need to access it, while all processes run on the SSD. How would I go about doing this?
I've had a few issues with shared folders that I had to restore back to Volume 1 multiple times and apps not wanting to be installed on another volume than Volume 1. Is it possible to move/rename my existing array to Volume 2 and somehow have the OS and everything on the default Volume 1?
Thanks!
T6-423 - TOS 5.0 - 3x16TB Seagate IronWolf Pro / 3x3TB WD Red/Green (BTRFS/TRAID)
TMLyy
Re: Moving OS/System, All Apps to SSD?
Post by TMLyy »
{L_BUTTON_AT}tres
SSD put the first disk and other hard disk reinstall the system to try, the volume name can only be changed by logining with ssh and using the command line.
tres
Post by tres »
Not sure I understand.
There is data on the TRAID array, you want me to take my existing drives out, install only the SSD and then reinstall the system? What about my original array?
Hi, you can reinstall the application and change the path to the SSD volume, but you cannot hibernate individual hard disks because all disks will run at the same time.
