network drive
Bubsel
network drive
Post by Bubsel »
Hello!
Can I also integrate the Terramaster F2-210 as a network drive in Windows without having to use the TOS software and then access the created folders?
Or is it absolutely necessary to use the NAS via the software?
Thank you and best regards
sianderson
Re: network drive
Post by sianderson »
yes, you do first need to create a share in the TOS web admin
but then any computer you can just navigate to \\NASDRIVE\ShareName
it will probably ask you to login with a user that you have set up in the TOS Web admin
but there is NO requirement to install the TOS Software on any computer, not even to set up the NAS drive in the first place
F2-424 TOS 7.0.0765
F2-423 TOS 7.0.0765
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Bubsel
Re: network drive
Post by Bubsel »
Excellent ! Can you possibly make me a step-by-step guide to recreate the exact processes?
Warm greetings
Re: network drive
Please refer to the article for help.
cruelliterate
Re: network drive
Post by cruelliterate »
Very detailed instructions. Is using via the software complicated?
Erik Pollard basket random
Return to “Others”
