Created second storage pool/volume, can't access first one
tres
Post by tres »
Hey guys,
as above, I created a second storage pool to create a second volume with three new drives. Now I can't access my old volume! I can still see Volume 1 in TOS and it looks like my data is still there but if I connect the NAS via AFP and my main admin user his folder is empty.
Thanks!
T6-423 - TOS 5.0 - 3x16TB Seagate IronWolf Pro / 3x3TB WD Red/Green (BTRFS/TRAID)
tres
Re: Created second storage pool/volume, can't access first one
Post by tres »
Just to add, my home folder for said user seems to now be located on Volume 2.
Go to Control Panel - Shared Folder, click "More" - "Advanced Settings" to restore the shared folders to the original volume.
tres
Post by tres »
TMSupport wrote: ↑21 Nov 2022, 17:47 Go to Control Panel - Shared Folder, click "More" - "Advanced Settings" to restore the shared folders to the original volume.
You are my hero, thank you!
tres
Post by tres »
This worked for now, but sadly after a reboot of the NAS the user folder is back to Volume 2 and is not visible in "Shared Folder" to set it back to Volume 1 as you suggested. :(
tres
Post by tres »
Another reboot and "Restore Shared Folders to Volume 1" later I can access the folder via AFP/SMB again, still the folder is not visible in Control Panel > Shared Folder.
The user folder will not be displayed in the shared folder list. It is normal if you can access it in file manager.
