[ aMule ] eMule-like client for the eDonkey and Kademlia networks
About: https://www.amule.org
Category: Download
Applicable TOS4: on request
Applicable TOS5: 5.0.135 or later versions
App download: https://tmnascommunity.eu/download/amule
username: terramaster
password: terramaster
To generate a new md5 hash password use this command in ssh
echo -n yournewpassword | md5sum | cut -d ' ' -f 1
or use an online hash generator like hash generator
Copy the new hash to variables below in amule.conf:
ECPassword=
Password=
PasswordLow=
TOS4 http(s)://yournasip:port/modules/appname/www
TOS5 http(s)://yournasip:port/appname
A Windows remote GUI can be used in addition to Web GUI
aMule is a multi-platform client for the ED2K file sharing network and based on the windows client eMule. aMule started in August 2003, as a fork of xMule, which is a fork of lMule.
aMule currently supports Linux, FreeBSD, OpenBSD, Windows, MacOS X and X-Box on both 32 and 64 bit computers.
aMule is intended to be as user friendly and feature rich as eMule and to remain faithful to the look and feel of eMule so users familiar with either aMule or eMule will be able switch between the two easily.
Since aMule is based upon the eMule codebase, new features in eMule tend to find their way into aMule soon after their inclusion into eMule so users of aMule can expect to ride the cutting-edge of ED2k clients.
Features
an all-in-one app called amule.
a daemon app called amuled. It's amule but with no interface.
a client for the server called amulegui to connect to a local or distant amuled.
amuleweb to access amule from a web browser.
amulecmd to access amule from the command line.
Re: [ aMule ] eMule-like client for the eDonkey and Kademlia networks
added initial version
eulero
Italy
Post by eulero »
Impossible to use, when i launch it this is the screen:
TOS5 last version available; modbase1 installed.
Current System:
F2-422 - 4TB storage
TOS- 7.0.0333
i dont have this issue.
Try to download again the app and install it, maybe you can also reboot your NAS
eulero
Italy
Post by eulero »
Thank you the reboot salved the issue.
But I want to highlight another issue now (I beg your pardon):
as you can see the message is different from yours, and above all it refer to a different port from 4711, but the message is wrong and the correct port is the 4711 as you can see:
Thanks bud and waiting for your help.
Eulero
Current System:
TOS- 7.0.0333
Download again the app and install it like in my previous message, the WebUI was adapted after your first message.
infoaliste
Spain
Post by infoaliste »
The application installs correctly but I can't activate it. when I try to activate it I get an error "operation failed".
do i need to install modbase or any other dependency?
Do you have a Volume1 available on your NAS ?
eulero
Italy
Post by eulero »
i had same issue .... installing modbase and rebooting solved the issue
Current System:
TOS- 7.0.0333
infoaliste
Spain
Volume1 I do not have exactly. For some reason in my nas it is called "Volume 2" even though I only have one volume created.
Anyway, after installing modbase, it seems that I have been able to activate Amule and access the interface correctly.
Thank you very much for your help.
