I just installed my F2 221 with 2 6TB drives and 10GB of ram.
This thing just dies in the desktop portal once you tell it do a file transfer. How with all this hardware is this OS so unresponsive when I ask it to transfer 50 gigs! My 10 year old synology would a least let me navigate the OS during a transfer. I give it a task and the the portal is unusable until the task is done, is this normal for this OS?
Desktop Application is Useless Under Load
Re: Desktop Application is Useless Under Load
Hi tm221,
May I know how you can have 10GB ram for F2-221?
I have dumped your operating system and have installed freenas.
Thread Closed.
Thread Closed.
Hi tm221,
I have found something wrong with your ram, that maybe the key reason to cause you so many issues.
1. the model F2-221 equiped a intel CPU J3355, the CPU supports max 8GB memory, but you installed totally 10GB memory;https://ark.intel.com/content/www/us/en ... 5-ghz.html
2. you are using a non official ram stick, this ram stick was not certified by TerraMaster, that may cuase many issues for you;
You better do something to your wrong hardware configuration.
I'm baffled by your response.
How is it that this machine functions great running both freenas and unrraid (freenas zfs cache pages all 10 gb of ram just fine), AND YOU SELL 8 GB SODIMMS FOR THIS UNIT?
