Hi All,
I own a D2-310, and have set a RAID1 (HFS format).
Was wondering, in a case of enclosure failure, would the drives be readable outside the enclosure, if connected via a simple SATA cable to a compute?
Also, would the answer be the same for different configurations (RAID0, Single, JBOD)?
Thank you,
Kay
Readable disks outside enclosure
Re: Readable disks outside enclosure
In most of cases, yes.
Just because of different RAID controllers used by different product , they may not be fully compatible.
