I'm currently struggling with my F2-210 as I'm trying to run a simple python script on it.
I created a docker image that runs successfully locally but cannot be imported into Docker on my NAS.
After doing some research on this board I've found this topic viewtopic.php?t=2341 which helped me out to understand that I need to create the image for the corresponding cpu architecture on the NAS. The problem is I still get an error message as I try to import the adjusted image.
Here is my example Dockerfile
#!/bin/bash
FROM python:3
ADD bot.py /
ADD .env /
RUN pip install -U discord.py==1.7.3
RUN pip install python-dotenv
CMD python3 bot.py
docker build -t python-courier --platform linux/arm64 .
docker build -t python-courier --platform linux/arm/v5 .
docker build -t python-courier --platform linux/arm/v6 .
docker build -t python-courier --platform linux/arm/v7 .
docker build -t python-courier --platform linux/arm/v8 .
Is anyone able to hint me into the right direction or can provide some solution?
