Docker update issue
Discussion about Docker
Authenticate
Docker update issue
Post by Authenticate »
Hello i updated docker, but now when i go to the application to enable it, nothening happens just failed
F2-425 (Non-Plus) 2x8TB 6.0.794
Re: Docker update issue
Which version was before the update? Please try to uninstall and reinstall the app.
unixtall
Post by unixtall »
I have the same problem too. I have updated the version today (11/10/2022) and i can not activate the docker engine.
Now i have tried to uninstall and install again, and the application center tries download three times(0 ... 100% ... 0% ...100% ... 0% ... 100%) and finally i got a error as you can see in the attachments. I dont know what to do. I tried to install in both disks.
philou669
Post by philou669 »
hello,
same thing here and all of my setup are in docker.
I uninstall and try to download and it's not working :roll:
help me please.
Model F2-420
TOS 5.0.176
philou669
Post by philou669 »
did you have trick to install docker with SSH command without docker manager? I really need docker in my setup
please
cliftonwknox
Post by cliftonwknox »
{L_BUTTON_AT}unixtall
I am having the same problem.
XFNeo
Post by XFNeo »
The same issue with update
BigHercules
Post by BigHercules »
Docker can be installed online now, please try again.
Return to “Docker”
