When i click disable on App center, it says Operation Failed! and remains enabled
If i uninstall it, when I install it again the app apears disabled
But if try to enable it again, it shows again the Operation Failed! message.
If i restart the NAS it shows again enabled and installed, but the 404 Not Found remains.
Another thing is that I'm trying to install manually with docker manager the portainer, but when i need to my Docker environment I don't know how to know my Environment address of the docker. How I can know it to connect the portainer to my docker?
