No SSH / Telnet connections to U12
las68
Post by las68 »
SSH / Telnet enabled. But when connecting to 9222, Putty reports connection timeout. Attempt to connect on telnet 23, or change port ssh to 22 gives nothing.
las68
Re: No SSH / Telnet connections to U12
Post by las68 »
SSH and Telnet seen in ports
las68
Post by las68 »
Problem solved.
By default checkbox 'Access SSH / Telnet from the same local network' is set. The 'same local network' means same VLAN. i.e if TNAS address is 192.168.200.100 you could access only from subrange of 192.168.200.x, access denied from any other network.
Please make sure you input the correct credential, or change a terminal and change again. You can also install a web base terminal and try from there.
viewtopic.php?f=37&t=2880
las68
Post by las68 »
As I told above, here is another root of problem.
The case of non-working AD join is still open.
