D5 300 Hardware reset
6ARP
Post by 6ARP »
Hi, thanks in advance for any help!
I have reformatted 5 x fresh drives to create a new raid5 on a d5 300, anybody know how I erase the old raid/ perform a full factory reset on the hardware please?
Many thanks
6ARP
Re: D5 300 Hardware reset
You can use the RAID manager client to delete your current RAID, and rebuild a new RAID. Before you do this, back up your data.
6ARP
Post by 6ARP »
Thanks for your reply. One of the problems is that since I followed the step in the raid creation instructions to use Disk Utility (Monterey) to erase the new the volume, the raid no longer shows in the manager so there is no way for me to delete it from there. Do I also really have to run terminal and copy/paste code each time I want to load the Raid Manager? Thanks
You have contacted after sales technical support. Good luck in solving questions or problems.
Return to “USB Series”
