F5-221 Sudden reboot
vvov75
Post by vvov75 »
Hi all!
Bought the device last week
Install auto TOS (4.2.39)
plug-in 4x HGST 3Tb NAS (HDD) - 2xRAID1 + (1+1) single hdd (yes, today, I learned that it is not supported :D )
during operation (watch movie by SMB for exemple), after a while, device emits 'bip' and going to reboot
i have tried:
- reinstall TOS4 from manual mode and with some version
- re-plug with 1or 2 HDD only
Please, advice on what I need to check ?
how can I look at the reboots reason ?
vvov75
Re: F5-221 Sudden reboot
Post by vvov75 »
SSH connected and find some errors in 'messages'
Oct 4 21:45:35 TNAS-1781 kernel: BERT: Error records from previous boot:
Oct 4 21:45:35 TNAS-1781 kernel: [Hardware Error]: event severity: fatal
Oct 4 21:45:35 TNAS-1781 kernel: [Hardware Error]: Error 0, type: fatal
Oct 4 21:45:35 TNAS-1781 kernel: [Hardware Error]: section type: unknown, 812 12a96-09ed-4996-9471-8d729c8e69ed
Oct 4 21:45:35 TNAS-1781 kernel: [Hardware Error]: section length: 0x290
Oct 4 21:45:35 TNAS-1781 kernel: [Hardware Error]: 00000000: 00000001 0000000 0 00000000 00020002 ................
Did you add memory to your TNAS? How often the issue happens?
vvov75
Post by vvov75 »
No, the device is out of the box
I already have the idea to see how the memory is installed
Do you think it makes sense to do that?
vvov75
Post by vvov75 »
TMroy wrote: 05 Oct 2022, 11:11 Did you add memory to your TNAS? How often the issue happens?
tried again yesterday. reinstalled the system on one disk and when copying on the network received several reboots for 10-15 minutes
vvov75
Post by vvov75 »
i've find somthing else intresting in logs
Maybe this help
Oct  4 21:45:35 TNAS-1781 kernel: Spectre V1 : Mitigation: usercopy/swapgs barri                                                           ers and __user pointer sanitization
Oct  4 21:45:35 TNAS-1781 kernel: Spectre V2 : Spectre mitigation: kernel not co                                                           mpiled with retpoline; no mitigation available!
Oct  4 21:45:35 TNAS-1781 kernel: Speculative Store Bypass: Mitigation: Speculat                                                           ive Store Bypass disabled via prctl and seccomp
Oct  4 21:45:35 TNAS-1781 kernel: Freeing SMP alternatives memory: 64K
Oct  4 21:45:35 TNAS-1781 kernel: smpboot: CPU0: Intel(R) Celeron(R) CPU J3355 @                                                            2.00GHz (family: 0x6, model: 0x5c, stepping: 0xa)
Oct  4 21:45:35 TNAS-1781 kernel: mce: [Hardware Error]: Machine check events lo                                                           gged
Oct  4 21:45:35 TNAS-1781 kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0                                                            Bank 3: b600000000110175
Oct  4 21:45:35 TNAS-1781 kernel: mce: [Hardware Error]: TSC 0 ADDR 5c9c0280
Oct  4 21:45:35 TNAS-1781 kernel: mce: [Hardware Error]: PROCESSOR 0:506ca TIME                                                            1664919920 SOCKET 0 APIC 0 microcode 1e
Oct  4 21:45:35 TNAS-1781 kernel: Performance Events: PEBS fmt3+, Goldmont event                                                           s, 32-deep LBR, full-width counters, Intel PMU driver.
Oct  4 21:45:35 TNAS-1781 kernel: ... version:                4
Oct  4 21:45:35 TNAS-1781 kernel: ... bit width:              48
Oct  4 21:45:35 TNAS-1781 kernel: ... generic registers:      4
Oct  4 21:45:35 TNAS-1781 kernel: ... value mask:             0000ffffffffffff
Oct  4 21:45:35 TNAS-1781 kernel: ... max period:             00007fffffffffff
Oct  4 21:45:35 TNAS-1781 kernel: ... fixed-purpose events:   3
Oct  4 21:45:35 TNAS-1781 kernel: ... event mask:             000000070000000f
Oct  4 21:45:35 TNAS-1781 kernel: rcu: Hierarchical SRCU implementation.
Oct  4 21:45:35 TNAS-1781 kernel: smp: Bringing up secondary CPUs ...
Oct  4 21:45:35 TNAS-1781 kernel: x86: Booting SMP configuration:
Oct  4 21:45:35 TNAS-1781 kernel: .... node  #0, CPUs:      #1
Oct  4 21:45:35 TNAS-1781 kernel: mce: [Hardware Error]: CPU 1: Machine Check: 0                                                            Bank 0: 9000000020000003
Oct  4 21:45:35 TNAS-1781 kernel: mce: [Hardware Error]: PROCESSOR 0:506ca TIME                                                            1664919920 SOCKET 0 APIC 4 microcode 1e
Oct  4 21:45:35 TNAS-1781 kernel: smp: Brought up 1 node, 2 CPUs
Oct  4 21:45:35 TNAS-1781 kernel: smpboot: Max logical packages: 2
Oct  4 21:45:35 TNAS-1781 kernel: smpboot: Total of 2 processors activated (7987                                                           .20 BogoMIPS)
Oct  4 21:45:35 TNAS-1781 kernel: devtmpfs: initialized
Oct  4 21:45:35 TNAS-1781 kernel: x86/mm: Memory block size: 128MB
Oct  4 21:45:35 TNAS-1781 kernel: PM: Registering ACPI NVS region [mem 0x7995a00                                                           0-0x79c7cfff] (3289088 bytes)
Oct  4 21:45:35 TNAS-1781 kernel: PM: Registering ACPI NVS region [mem 0x7a32000                                                           0-0x7a320fff] (4096 bytes)
Oct  4 21:45:35 TNAS-1781 kernel: clocksource: jiffies: mask: 0xffffffff max_cyc                                                           les: 0xffffffff, max_idle_ns: 1911260446275000 ns
Oct  4 21:45:35 TNAS-1781 kernel: futex hash table entries: 1024 (order: 4, 6553                                                           6 bytes)
Oct  4 21:45:35 TNAS-1781 kernel: xor: measuring software checksum speed
Oct  4 21:45:35 TNAS-1781 kernel:    prefetch64-sse: 10584.000 MB/sec
Oct  4 21:45:35 TNAS-1781 kernel:    generic_sse:  9100.000 MB/sec
Oct  4 21:45:35 TNAS-1781 kernel: xor: using function: prefetch64-sse (10584.000                                                            MB/sec)
Oct 4 21:45:35 TNAS-1781 kernel: RTC time: 21:45:20, date: 10/04/22
Basically, it should be able to determine the existence of problems.
Please collect a log in "TOS>Technical Support>Issues Report" and provide it to A for further analysis.
If necessary, they will tell you how to conduct after-sales treatment.
vvov75
Post by vvov75 »
Thanks!
send to support
vvov75
Post by vvov75 »
Hi support team!
two days ago send logs on support
no activity
How long does it usually take?
And one more question..
Have BIOS version (find screenshot)
maybe i must update it?
TMnorah
Post by TMnorah »
Could you please leave the name of your email address? We will reply as soon as possible.
